Ceiling fiberglass insulation in basement
The basement of the home is 90% finished. Their is a room that has the plumbing/electrical (hot water tank, well tank, main electric panel, gas fired furnace for hot water baseboard, etc.). This room is also used as storage and has a spare fridge freezer in it so it gets some use. This room is unfinished and has exposed pink fiberglass insulation in the ceiling with the paper side up (so you can't see it). I rather not remove as it provides sound dampening (slightly) to the living room above and keep the floor slightly warmer. I do not want to sheet rock this area as there are several plumbing runs in the ceiling. Would perforated relectix be good to cover this to keep the fibers from dropping and being breather/spread? It's rated as A class 1. I want something that is fairly fire friendly in the worse case scenario but also allows this to breath.
Other opinions are welcome
Thanks,
Thanks,
Don't think you need to be worried about it "breathing" since both sides are conditioned space. Should be a good product to use since you need to use a fire rated material.
You really need to cover the fiberglass, it will continuously shed fibers and they are not good to breath. At a min cover with plastic!
It's 6 inches thick and I rather not remove and spend money on other sound supressive product at this time.
any other ideas besides the plastic or perforated refletix that is better fire retardant that can be stapled up. (Not drywall as mentioned.)
Tyvek barrier would work!
I wasn't suggesting to remove, just that regular old fiberglass is not the greatest sound barrier!
