Detached heated garage - do I need a vapor barrier?
Old 11-09-18, 09:38 PM
  • Climate: Chicago, 0-35 degree F winters.
  • 2-car detached wood-framed garage, unfinished, concrete slab.
  • Pyramid hip asphalt shingle roof, plentiful ventilation through soffitt vents and roof vents.
  • Installed a natural gas ceiling-mounted blower heater, will be running about 50% of the time, possibly 100% if gas bill doesn't get too high.
  • Planning on blown fiberglass insulation in attic, fiberglass kraft-faced batts in walls, 1/2" drywall over everything.
My question is, do I need a plastic vapor barrier on the ceiling in between the drywall and the framing? I've read that you should ALWAYS use a vapor barrier and that you should NEVER use a vapor barrier in similar situations...grrr.
Please advise, thank you!
Old 11-10-18, 12:26 AM
Received 1,178 Likes on 1,136 Posts
Current convention is not to use a vapor barrier. That said, air sealing before installing the insulation can do almost as much as the insulation itself. Personally, I prefer mineral wool to fiberglass.
Old 11-10-18, 05:22 AM
K
A little late I admit, the critters do not have any love for rock wool( wear a mask when you install itas with fiberglass)
One problem with an unheated garage would be "sweating" when humid warm air was introduced to the structure, we have a similar situation as yours and I left the vapor barrier on and have had no problems.
Consider this( I know its late) treat one wall differently than the others and see if problems develop.
Old 11-10-18, 05:40 AM
Marq1's Avatar
Unless you have a way to manage moisture in an enclosed space never use plastic, it will completely trap moisture which can lead to water/mold issues.
All houses need vapor barriers, this slows down the transfer of moisture but does not block, big difference.
However, you are insulating a garage with huge doors with big gaps so the issue is sort of mute!
Old 11-10-18, 06:20 AM
Got it - thanks guys!
The message you have entered is too short. Please lengthen your message to at least 25 characters.
