Shut off power when insulating?
Old 01-11-19, 12:34 PM
A
Hello, this may be a ridiculously stupid question. I am insulating a wall in my laundry room this weekend. Is it best practice to cut the power when I am doing so? I just don't know what wires are currently in the wall.
Thanks in advance.
Old 01-11-19, 12:50 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
Well you shouldn't be using your knife anywhere near wires if you cut on the floor or on a work bench, so I would say no.
Old 01-11-19, 01:46 PM
Received 5 Upvotes on 5 Posts
Yeah, you should be cutting the bats to length on the floor. You may have to slit them to work them around wire cables, but the risk of cutting them should be slim to none. If you feel safer, kill the c/b.
Old 01-11-19, 02:10 PM
A
Ok, thanks. I know not to cut near the wires, just didn't know if incidental contact would be dangerous. I'd rather keep the power on if I can.
Old 01-11-19, 02:21 PM
XSleeper's Avatar
Nothing should be dangerous if all the wires terminate in boxes. If there are any wire nuts or taped connections that aren't inside boxes then that would be a problem with how it was wired. Junctions need to be in a junction box and they need to be accessible, not buried inside a wall.
