Spray in expandable foam insulation
Old 05-27-01, 02:40 PM
I will be constructing a new home within a year around the Houston, Texas area. I once saw a TV program which had a two part expandable foam insulation that was sprayed in between the studs after all other components were installed. At the time, it appeared to be the "future" of insulation. I haven't heard much about the process lately and was wondering if it is a viable option for new home construction? Is the cost prohibibtive, is the effectiveness worthwhile, is it readily available. Please help.
Old 05-29-01, 05:10 PM
Insulman
The product is used in Michigan... In The Metro Detroit area it is not used alot, but is available. I would have to guess that the cost is approximately 40% more than using fiberglass batts.. The question of whether or not it is worth it is hard to answer in my opinion.. I believe any insulation whether, expandable foam, Blown in cellulose or fiberglass will do a great job if it is installed properly..
If nothing else I would suggest using expandable foam to seal all exterior wall openings.. ie windows doors etc as well as behind outlets on exterior wall.
you might try http://www.icynene.on.ca for more info
Good luck
Jim
Old 05-29-01, 05:14 PM
Insulman
The linc I posted was not working
I found this link though... http://www.aesinct.com/Icynene.htm
It might answer some of your questions..
Jim
