Old House Insulation
Old 06-03-19, 09:28 PM
I
I have a 100 year old house; no insulation; no soffit ventilation; the attic has blow in insulation and the roof as 4 vents; 3 in the warmer south side and 1 on the north side. The house is 1 1/4 storey; part of the wall in the 2nd floor is the ceiling. That part is about 5' with a 12/12 pitch until it meets the ceiling.
After having a bathroom renovated; the contractor used pink 2x4 insulation in the 2x4 walls and part ceiling/wall. I do not believe he used baffles for venting as he never deepened the 2x4 wall to allow for the baffle/insulation
I have recently demo'd and insulated a small hobby room with that approach for the ceiling (no baffle)
I have started to demo my bedroom and it was pointed out that I should install a baffle; I am in the process of doing that. In hobby room case I deepened the wall to 2x6 to allow for 2x6 insulation. In this case I'll have to deepen the ceiling to allow for the baffle and 2x4 insulation.
My question is; do I have to revisit my old project and install baffles in the hobby room? In an old house with little to no soffit ventilation. Are there any options I can look at before I tear again into my hobby room wall/ceiling to install baffles? If I don't do this am I kicking the crap out of my roof since the roxul is touching the roof?
Is there something about ventilation and old houses that I am not clear on?
Old 06-04-19, 05:15 AM
P
Received 2,014 Upvotes on 1,806 Posts
Baffles are only used in roofs. Baffles are only used when there is air movement between soffit vents and the attic vents. So, if you have a roof area that's not ventilated or if you don't have soffit vents then you don't need baffles.
joecaption voted this post useful.
Old 06-04-19, 09:50 AM
B
Received 47 Upvotes on 43 Posts
But you also don't want the fiberglass insulation in contact with a cold roof. Sorry, just jumping in.
Bud
