Sealing around registers
Old 02-29-20, 06:53 AM
Received 1 Upvote on 1 Post
EDIT: I just realized this should probably be in the energy usage / weather stripping forum, but I'm not sure how to move the thread.
I'm replacing some return register covers, and it looks like I need to seal the duct to the drywall (see picture). Is Is it better to use a foam like great stuff, silicone caulk, or dry wall putty to fill the gaps before taping? Is metal tape by itself enough?
Old 02-29-20, 07:56 AM
Tolyn Ironhand's Avatar
Received 913 Upvotes on 771 Posts
If the new covers will cover the gaps I see no reason to fill the gaps. They are not causing any issues.
Old 02-29-20, 08:07 AM
There is noticeable cold air coming in from the gaps, so this is to create an air seal. It's an older brick house and I do not think there is much if any insulation between the drywall and the brick.
Old 02-29-20, 08:42 AM
2
Received 398 Upvotes on 347 Posts
Self-stick foam weatherstrip applied to the back of the register cover will cover the gap and seal the edge enough to prevent air infitration. Half inch or 3/4 inch wide--as much as the register overlap will allow.
JAHMD voted this post useful.
Old 02-29-20, 08:57 AM
XSleeper's Avatar
Received 1,974 Upvotes on 1,770 Posts
You can probably get some duct from the big box and insert it into the inside of the duct. It should have a little flange around it that is about 1/2" wide. That flange can then be caulked and pushed tight to the wall to fill and cover the gap.
Old 02-29-20, 09:14 AM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Then by all means gety a canof low expansion foam and start as deep inside as the nozzle will allow, fill some, wait an hour then fill more till it's oozing out then trim flush!
Old 02-29-20, 10:26 AM
XSleeper's Avatar
If you do use foam I would recommend the Dap latex foam. It's easier to clean up with water.
Old 02-29-20, 11:02 AM
Thanks everyone, it seems like any of these options should work.
I have several registers that I expect have the same problem, so I think the low-expansion latex foam, cut flat, with metal HVAC tape over the top will be the easiest. The flanged duct makes sense, but I think I'd need to get multiples and the drywall as is might be difficult to get a great seal with caulk.
Old 02-29-20, 11:09 AM
Just to confirm, is this what you mean: https://www.acehardware.com/departme.../caulk/1096189
Old 02-29-20, 11:58 AM
XSleeper's Avatar
Yes.
Old 02-29-20, 01:55 PM
Seems like it worked pretty well and cleanup was easy. It definitely would have been a pain with the non-water cleanable foam.
Do I need to wait for it to cure or can I tape over it with metal tape at this point? Is it not going to cure without enough air exposure?
Thanks everyone for your help!
