How to insulate this door?
Old 06-26-21, 02:36 PM
I checked with my temperature gun and found 10 F difference. This door opens to a space in the attic in between. See the pictures and I want to know the best way to insulate it. Maybe be behind the door as well not just around the corners? I am not sure.
Old 06-26-21, 04:49 PM
P
Received 2,107 Upvotes on 1,886 Posts
Screw or glue a piece of rigid foam insulation to the door. Also get some weatherstripping to seal off the door so no air can pass around the edges of the door.
pbct2019 voted this post useful.
Old 06-26-21, 05:29 PM
Which rigid foam is the best? or what type of foam insulates the best?
Same for weatherstripping so which one is the best?
Old 06-27-21, 02:02 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
You could also replace with an exterior style door, a little more work, better results, would look neater!
