Crawlspace stud wall insulation and covering question
Best way to insulate this crawlspace exterior wall? Wall is roughly 10 feet long and 30" high. This is in the borderline of climate zones 5&6 in MI. Currently a dirt floor, but looking to get some plastic over it at some point.
Have the same wall just a little ways down(mechanical room where all the wires are coming from) that I would like to remove exisiting covering-its not drywall..old 50's-60s wood paper board stuff..and the insulation and airseal things up and insulate and board. Same line of attack?
THanks!
Correcto on cold floors. This is a 'summer home' and this is our first winter with it and thankfully dont spend alot of time there yet. Finding lots of things to attack as far as weatherizing. I agree on the foam, but I cant leave that exposed can I?
Foam in the crawl space isn't "exposed" as it's inside and protected from UV (sunlight). Spray would be the best but perhaps too good. Rigid foam sheets can be cut to size and would be much less expensive and could be easily removed in the future if needed.
Do you have wood eating insects in your area; termites, carpenter ants...? If so I would check the house's insecticide treatment history. If termites are common in your area I would make sure the house is treated before foaming the foundation walls. Termites can bore tunnels through the insulation and the foam will conceal their mud tubes so it's best to treat to insure that you never have that problem.
Followup question, Have vented crawlspace for addition with insulated floor and hanging flexible heat ducts. Room above is too cold (warm in A/C season) and it seems like the ducts would perform better if their surroundings were warmer, Crawlspace floor and walls are concrete. Can I also insulate the walls? Research I have done says floor/wall insulation is one or the other, not both, Oh, and also ducts are drooping like wet noodles because trimming and dressing were poorly done. Am I correct in assuming there would be benefit in eliminating the droop so air doesn't take a roller-coaster ride?
Yes, insulate walls or ceiling, not both. You insulate the ceiling if the space is open to the outside air and sealed from the house. You insulate the walls if you seal the space from the outside and open it to the conditioned air of the house. The latter is how you warm the floors above the space.
Hi,
I have had to walk in my attic quite a bit unfortunately and I have moved my blow in insulation around.
What is/are the right tool/tools for the job?
Thanks.Read More
Sorry if I posted this twice - new member:OK, a bit of background on the structure in question; it's an off grid house with 2 x 12 open rafters. Roof is typical; plywood deck, felt paper, asphalt shingles - then overlaid with metal roofing. There is a wood burning stove inside, and I will be putting in a direct vent propane heater as well. But neither will be utilized frequently as this is a seasonal dwelling with no access during the winter months. Temps range from -30 in the winter to 90 in the summer. Very low humidity year round (9000 feet up in Colorado). No insulation in the ceiling at all, and that's what I want to add, and add economically cuz I ain't made of money.
So here's the question; would there be moisture issues if I were to push 2" thick painted rigid foam up into the rafter cavities, then simply hold them in place with perimeter quarter round? There is no air circulation in the cavities and I want to keep the rafters exposed.Read More
