Drilling Through Insulation
Old 01-31-23, 06:25 AM
W
I have to pass a 3/4" conduit through a 2x6 wall that contains pink fibreglass insulation. In the past I recall my typical drill bit snagging the insulation as it passes though.
Is there a technique or method to drill through the insulation ?.....or is it just better to open up a space by wiggling a screwdriver or rod side to side ?
Old 01-31-23, 08:49 AM
P
Received 1,776 Upvotes on 1,588 Posts
Wiggle and stick is what I usually do. I also feel it allows the insulation to seal around the pipe or conduit better than if you'd cut and removed insulation.
