Fiberglass Insulation over electrical wiring
Old 02-15-23, 06:07 AM
G
Hello,
I am replacing my fiberglass insulation at the rim joists and when I pulled the old insulation away there are electrical wires running along the rim joists. Obviously, they are sealed/covered with whatever they come with running from the electrical box but is it fine to put new fiberglass insulation back over these wires?
In other areas of the rim joists I am going to use rigid foam as well but since these wires are very close or even attached to the wood on the rim joists, I may be only able to put fiberglass insulation over them.
Just wanted to check if this is ok? I would assume so since I bought the house it previously had fiberglass insulation over them but just wanted to be sure. I don't really know of any other option to insulate that area.
Thanks!
Old 02-15-23, 07:33 AM
P
Received 2,265 Upvotes on 2,018 Posts
Yes, it is safe to insulate over or around modern, insulated wiring like Romex/NM.
In older homes DO NOT insulate over or around knob and tube wiring. This is some of the oldest types of wiring and can have exposed, uninsulated conductors. This type of wiring relies on open air space around the wires for cooling. Insulating over them can cause a fire.
Guitarplyr voted this post useful.
Old 02-15-23, 08:09 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Wiring in exterior walls comes in contact with all types of insulation!
Old 02-15-23, 09:31 AM
G
These are the wires in question:
So definitely ok to put insulation over them?
Old 02-15-23, 09:33 AM
Received 869 Upvotes on 760 Posts
Those cables will be ok covered with insulation.
