insulation
Old 07-13-01, 06:38 PM
Guest
I AM INSULATING A SMALL WORKSHOP USING PAPER FACED 3 1/2INCH FIBERGLASS.THE SHOP HAS A METAL ROOF AND WILL BE ABOUT 4INCHES ABOVE THE INSULATION, WILL THIS BE ENOUGH AIR POCKET? ALSO WHAT PRECATUIONS SHOULD I TAKE FITTING THE INSULATION AROUND ELECTRICAL BOXES? THANKS, FLINT
Old 07-14-01, 03:35 AM
A
The four inch air space you have is plenty. But is 3 1/2" insulation enough where you live? Use gasketed electrical boxes on the ceiling to prevent air leakage. The insulation can go tight against & over the box. Make the ceiling as air tight as you can by using a 6ml. polyethelene vapour barrier under the insul., caulked at all joints. Moist air contacting the cold tin will condense & soak your insulation.
