spray insulation or fiber glass batts?
Old 04-23-24, 08:05 PM
R
Wondering if I should get spray on insulation, closed cell, in a new cabin. Have heard some health concerns over the year but not sure what is or isn't true. Any input would be great.
Not opposed to installing fiberglass. Have swam in my fair share over the past 30 something years and it doesn't bother me or send me into a scratching frenzy.
Old 04-24-24, 01:17 AM
Received 1,273 Upvotes on 1,213 Posts
Any reason not to use mineral wool?
Old 04-24-24, 05:48 AM
P
Received 2,236 Upvotes on 1,995 Posts
Each has it's own pro's and con's. Spray foam offers some of the highest R value per inch and is generally a vapor and air passage barrier but it is expensive. So, most homes are still built using fiberglass or some other more traditional insulation.
Old 04-24-24, 06:28 AM
Received 863 Upvotes on 755 Posts
and while you can diy spray foam it's not all that diy friendly
Old 04-24-24, 02:30 PM
Received 4,057 Upvotes on 3,640 Posts
Spray foam is superior but it MUST be covered.
It is not flameproof and cannot be left exposed in the living area.
I would never hesitate to spray foam my home if I could afford it.
Old 04-26-24, 03:54 AM
R
Stickshift, I have a enough left over rolls of faced fiberglass from another diy project.
PJ, when you say covered do you mean sheetrock? What other materials would you cover with?
Got one bid for spray, about $5 per square foot, seems way high according to a quick google search.
Old 04-26-24, 04:50 AM
P
Spray foaming is very expensive. There is a reason the other insulations are still more popular.
