Finishing a polebarn interior
Old 01-22-02, 04:21 PM
Guest
Question Finishing a polebarn interior
I just built a polebarn and would like to finish the interior. I plan on using 2x6 stud walls . Should I put a vapor barrier on before I stand the walls up or should I put it on after I insulate? I have been told not to put anything up against the metal siding because this would hold the moisture. What type of vapor barrier should I use and how should I insulate?
Old 01-23-02, 07:20 AM
Insulman
If your installing the 2 x 6's 24" OC, then I would just use R-19 Kraft faced batts. Install the vapor barrier towards the inside. This is of course if you are planning on covering the insulation with drywall.
Good luck
Jim
Old 01-23-02, 09:12 AM
ynotwa
Thanks
I am in the process of doing the same thing but instead of pole barn walls I am remodelling a loft. Would the same thing apply to roof in on 26" oc studs and I was thinking of the vent inserts then, insulation and then a vapor barrier. For the walls I am planning on using exterior bord and bat.
thanks
Old 01-23-02, 09:13 AM
ynotwa
R-19?
What is the R-19 that you refered to by the way?
