Insulating crawl space
Old 01-31-02, 07:07 PM
Guest
I have a beach house in the Puget Sound area which is supported by concrete piers about two feet above a gravel surface that frequently becomes damp. There is no foundation surrounding the house. The subfloor is constructed on top of beams with a 4 foot spacing. I would like to insulate the floors and would like recommendations for doing this, i.e. R-value, type of insulation, use of plastic vapor barrier, etc. Thank you.
Old 02-01-02, 04:59 PM
rbisys
Greetings,
If you use any type of fiber type insulation in this application you will have nothing but moisture problems.
I would install two layers of radiant barrier insulation (RBI) between the beams and then aluminum soffit material below that.
The RBI will reflect 97% of the heat energy back up to the floor.
The Aluminum soffit material will protect the RBI from wind effects and also act as a moisture barrier against the ground moisture.
Thank you for considering my opinion.
