garage insulation
Old 02-18-02, 12:51 PM
LadyDi
garage insulation
I would like to insulate my unfinished garage. What r value is recommended for a mild climate? I intend to install drywall after insulating.
Old 02-18-02, 03:05 PM
Insulman
R- 11 or R-13 is all you need for the walls. If your going to heat the garage all the time then i would put r-19 in ceiling. If your not going to heat the garage except for occasional use, then again I would go with R-11 or R-13..
Good Luck
Jim
