Drafty House
I just remodeled a 22 year old home. The 4 ton heat/air unit is on a true vaulted roof, I'ts 3 years old. After putting in energy saving lights, and new R-38 in the attic this old 2 story still has issues.
The registers pump out the heat near the inside intake, but upstairs and down, the registers can hardly keep up with a trickel of air.
Then when the heater is off and you stand underneath the intake register you can feel a light, but steady cold breeze.
Is there a do it your self way to cheak for duct seals or air-tightness without having to hire some $55.00 hour HVAC guy just to tell me my ducts are loose ???
Any help out there??
Moderator Note:
Since there are other issues that may need attention and correcting to further resolve the drafty conditions and you already have the answer to the heater problem, I moved you topic to the insulation forum.
Doing so offers you ideas & suggestions for insulating the home.
Regards & Good Luck, Heating & Cooling Forum Moderator.
TCB4U2B2B Company Enterprises.
Fast, Fair, Friendly & Highly Efficient Service.....
Energy Conservation Consultants & Gas Appliance Problem Diagnostics Technicians.
Moderator Note:
So I'll tell you for free. You got ducting problems. It's a search and destroy type thing. You'll have to check connections, gaps, etc. on all your duct work, supplies, and returns. Good luck and 55p/hr is cheap.
You can go to http://www.resercon.com/Low.html you have what is known as a low velocity system and it explains how your system works. It also discusses leaky ductwork and how to seal them.
Previous Thread
Next Thread
