insulation and metal studs
jpbaker10's Avatar
03-27-02, 08:52 AM   #1
jpbaker10
I framed my basement using metal studs. I brought it out 4 inches from the poured concrete walls. My quetion now is how do I attach the insulation to the metal studs. I heard somwhere that I can apply a spray adhesive to the back of the insulation paper and just glue it to the concrete. Is that ok, or does that sound ridiculous?
NorthInsulator's Avatar
04-03-02, 03:25 PM   #2
NorthInsulator
metal studs in the basement
good choice on the metal studs
metal framed sized batts are your answer here
no need for " attaching " them to the framing
but you will not find them in the local home center
call a pro company that handles residential and comercial installs
they may be able to supply and install the correct dimension material
