Cellulose insulation....general questions
Old 05-09-02, 09:06 AM
bobtroy
Question Cellulose insulation....general questions
I have a house which is completely insulated, except for one room which was added after. Do I do all 4 walls, or just the 3 outside walls. I am going to blow it in from the inside. There is a crawlspace underneith the room. Should I insulate that also? If so, should I completely cover, or just a few inches? Thanks for the help.
Old 05-11-02, 08:38 PM
R
The rule with insulation is the surfaces that separate the inside from the outside should be insulated. This is referred to as a thermal boundary. So the 3 outside walls and the floor in the room shound be insulated.
