fiberglas batts or blown cellulose
Old 05-30-02, 06:54 AM
MsAnnie
As part of a second floor remodeling I am ripping out the ceiling of my 1955 cape second floor and insulating - it is extrememly hot up there in warm weather! I have had two quotes from insulation guys - one will use fiberglas bats - the other will use a combination of batts and blowin in cellulose where feasible. In all my research, folks who don't like fiberglas call it filterglas - because they think it allows air and moisture to go right through it. Those who don't like cellulose say it settles and you lose effectiveness over time. Help!
Old 05-30-02, 09:50 PM
T
Types of insulation
Different kinds of insulation and concerns
http://www.resercon.com/Insulation.html
R value of loose fill insulation is calculated based on thickness after settling. Thus, the settling is taken to account when calculating the amount needed. See the following chart http://www.greenstone.com/LooseFillC...art.asp?Type=R
One of the advantages of loose fill insulation is that it can cover nooks and crannies and gaps that otherwise would not be covered when laying out batts of insulation.
Remember there is a point of diminishing returns when it comes to how much insulation you install. Find out how much insulation the Dept. of Energy recommends for homes in your area:
http://www.houseandhomesite.com/article1021.html
