Insulating under eaves
Old 06-04-02, 03:54 PM
Question Insulating crawl space off of bathroom
I am not sure what to call the area that I want to insulate. I bought an old house recently and there is a space under the eaves that is accessible from the bathroom. The area is roughly in the shape of a right triangle with the roof forming the slope. This space forms part of my bedroom wall and most of one bathroom wall. The bathroom is cold in winter and hot in the summer. There is currently no insulation in this space. The previous owners tacked up some cardboard. I have some questions about how to best insulate this space.
1. I am assuming that it would be best to remove the cardboard, correct?
2. Do I insulate the floor, walls, and roof?
3. Do I need some type of vapor barrier?
Any help would be appreciated. Thanks.
Old 06-04-02, 08:48 PM
J974
You should insulate the wall or ceiling that meets the heated space. If these walls are outside walls they should be insulated using a vapor barrier. If their are vents in your eaves you do not want to cover these areas with insulation.
Old 06-04-02, 11:49 PM
T
Insulating attic
Go to http://www.resercon.com/ to learn what an expert has to say about insulation, ventilation, and thermal boundaries.
Click the following for search results to this frequently asked question and to read posts about what others have reported:
http://forum.doityourself.com/search...der=descending
Old 06-05-02, 08:47 AM
Thanks
Thanks for your help.
