Hostas
Hostas
i am putting white marble chip rocks around my above ground pool. could i plant hostas in them and have the rocks cover the area below the plant right up to the stems, or do i need to leave space around the plant itself? will chlorine kill/damage them if they get splashed on?
If you plant hostas in the white rocks, be sure to get the ones that will do well in that bright, hot environment. Many hostas are shade-loving plants.
Splashing chlorine on plants will damage them unless the chemical is rinsed off quickly.
As indicated, hosta prefers shade to partial shade. The rule of thumb is the darker the green, the less sun. Those white marble chips will absorb sunlight and radiate heat. I don't think hosta would be a happy camper in this environment unless pool area is shaded. Plants and chlorine tend not to be compatible. But if you hose off plants after a splashy swim, you may do quite well.
