Decorative stone etching
Old 01-24-06, 09:15 AM
I would like to put right outside our front door some flat stone. I don't want to cover the yard, just a few with carvings/etchings in them. Is there a "recommended" flat surface stone, that would carve easily, but still take the abuse of outdoors without washing the etching away? I will be using a Dremel to do the etching if that helps.
thanks
matt
Old 01-26-06, 01:01 PM
Thanks for looking at an odd question..
I decided to try a few different bits for my Dremel and found a bit that will work. I tried on just a "normal" brick and worked just fine. It's just going to be slow going, so I don't make crooked lines. Thanks for all that looked.
Old 01-26-06, 01:23 PM
majakdragon's Avatar
Good luck with your project. Going slow will certainly produce better results. I use my Dremel a lot. Found that the router base attachment is really good for control.
Old 01-26-06, 07:54 PM
corded vs. cordless Dremel
majak...
I love my Dremel. I have the lith-ion cordless version. Do you have one of the corded? I keep looking at the new 400xpr (or whatever model it is), and am thinking of getting a corded.
Old 01-26-06, 08:05 PM
I have the corded model. 400 XPR with all the attachments is next on my list.
Old 01-27-06, 12:13 AM
If you happen to get it soon (or before I do), can you send me a simple pm letting me know how you like it?
thanks
matt
