Retaining wall garden boarder
Old 07-13-06, 11:00 PM
I am building a double stack retaining block garden boarder. I want it high enough so the grass and garden don't mix. How far below the grass line do I need to bury my first block. Also, do i need to use that garden lining underneath and in between the blocks and the soil for the garden?
Thanks in advance for the help.
Old 07-14-06, 05:39 AM
What is a double stack retaining wall?
What is the elevation distance between the grass and the garden area?
It sounds like a typical application for segmental retaining wall block (without doubling) that are available everywhere.
Dick
Old 07-15-06, 01:03 PM
I have the same questions. What's a double stack retaining block? If you sink the block down halfway into the soil you shouldn't have any invasion of grass.
Newt
Old 07-15-06, 02:16 PM
Instead of useing one row of retaining blocks I was going to use 2 rows, making the boarder taller (higher). The blocks are 4 in. in height, so the boarder would be 6 in. high (if i bury half of the first row of blocks). With it being this high, would i need to worry about putting a lining between the garden soil and the blocks?
Old 07-15-06, 03:06 PM
It sounds to me like you are just doing an edge, not a retaining wall, but using the blocks for retaining walls. Is this the block you are using? It requires a cap as you can see in the pic.
http://www.northstar-stone.com/retain.html
http://www.kingsmaterial.com/images/rwabab_gallery2.jpg
This site shows the first block buried halfway into the soil.
http://www.rd.com/content/openConten...ontentId=18258
Here's a simple two stone high, but it's sitting on a brick patio. It will give you an idea of what it looks like without the cap.
http://www.rock-shoppe.com/images/wallsSantsar.jpg
Edging ideas.
http://www.hgtv.com/hgtv/gl_design_p...398441,00.html
http://www.ncarnevale.com/edgers.htm
Newt
