Best way to cut pavers?
Old 07-27-06, 04:19 PM
What is the best way to cut paving blocks without a masonary blade. If that is the only way then i will get one. if there is any easier and just as efficient way I would appreciate the help. Thanks
Old 07-27-06, 08:01 PM
If you are using concrete pavers, you can split them.
If you do not have too many, you can use a mason chisel and a hammer.
Usually, you can also rent hand splitter from a paver dealer or an equipment rental outfit. A good dealer can help you are steer you.
Dick
