3/4 supply for sprinklers
Old 05-28-07, 03:18 PM
I need to run a 3/4 supply line from the front of the house to the rear to solve a problem with low pressure in the back yard sprinkler system. As far as making the run underground along the house, should I use copper pipe under ground next to the house, or is it OK to use PVC? Are there different depths that are recommended for each? It will be running along side and within less than a foot of a PVC electrical conduit that leads to a water feature in the back yard.
Old 06-02-07, 05:48 AM
PVC will be fine. It's made for what you plan to use it for. If you ar concerned about the strenght, you could use sch40 but don't need to. The front depth has to do with where you live(most places 12 to 18 inches) not with the type of pipes you use. good luck
