Toro Vision II Program A and B???
Old 07-25-07, 09:43 AM
Question Toro Vision II Program A and B???
The sprinkler turned on unexpectedly a couple of times in the first couple of weeks. I suspect that I did not program it correct. I don't have a users manual, but do have a quick guide. I search the www.toro.com without luck. I guess this model is just too old. I can figure out most of the settings, except the Program A/B. This is a Vision II series with gray plastic cover. Does anyone in this forum know how to set this?
Thanks.
Old 07-25-07, 10:14 AM
Is this what you have?
http://www.grasslandcorp.com/Vision_II_user_Guide.pdf
I think that should help ya out some.
Old 07-25-07, 11:55 AM
Thumbs up
Well, this is not exactly what I have. Mine is Vision II, not plus. But, it has enough information about the Program A/B. This part should be the same as my model.
You guys are good. Thanks very much.
Old 07-25-07, 02:22 PM
Here you go:
http://www.toro.com.au/files//Vision%20II%20Booklet.pdf
Let us know how it works out
Old 07-26-07, 07:57 AM
This is exactly what I have. I have re-programmed my controller. I should know if I did correctly in two weeks. If not, you will hear from me again.
Thanks.
