Need to get rid of pea gravel
Old 05-09-08, 10:04 AM
Hi, I'm tearing out a dog run that has maybe 3 yards of pea gravel in it. I can't find anybody who can haul it away. I've called at least a dozen rubbish removal, landscaping, and gravel companies. Nobody knows who can help. I posted a free ad on Craig's list, but who knows if I'll get a response anytime soon.
So, my idea is just to reuse the gravel under my deck. I have a large deck that already has gravel under it, but it's probably only 1/2" thick. Is there any problem with adding to that gravel? I have pretty good access under the deck, so that is not a problem.
Any advice? Thanks!
Old 05-09-08, 10:32 AM
There should be no problem using it under your deck.
Just spresd it evenly over your existing rock. They both are clean draining materials. I assume you hove poly under your existing rock. If iy gets too thick, you many need some edgomg to keep everything where you want it.
Dick
