Wet Saw for stone block retaining wall?
How do I handle the inside and outside corners when building a stone block retaining wall? Will I need to rent a wet saw to cut the corners at a 45 degree angle?
A diamond blade concrete cutting saw might be a better choice over a wet saw. Using a specific saw, especially a rented saw, beats using a concrete cutting blade on your circular saw only to find that the dust has destroyed the unprotected motor and bearings.
Stumped1 -
If your retaining wall block are one of the national/international brands, you could go to their web site. Most have great ideas, corner details and installation instructions. Planning is important since the walls have a slight batter to them anf that really effects the corner details. Just like all masonry, you do the corners and ends first.
Each has a site (Allan Block, Anchor Wall Systems, Keystone and Versalok) that you can find by Googling.
Many contractors and DIYers do not bother with a saw, but just use a chisel to split the units to the appropriate length.
Dick
Dick
