My Sprinkler station won't turn off
Old 06-09-08, 10:24 PM
I have an irritrol sprinkler system that has worked for years. When I turn on station 1 it goes on fine, but then when I try to turn it off it will not do so when I hit the off button. It will only turn off when I turn the dial to "rain off" or turn off the main vavle in the ground. It also does the same thing when it cycles through the preset program. Instead of station 1 turning off it will remain on and station 2 will also turn on and water at the same time. What is causing this???? Help!
Old 06-17-08, 04:12 PM
Disconnect the #1 wire in the controller when the timer switches to #2 zone and see if that shuts it off, if it does not shut off then you have a valve problem if it does then you have a controller problem. Do you have any programming on B&C programs?
