fyi privet stinks
Old 06-13-08, 09:30 AM
fyi privet stinks
a while ago I posted a request for a recommendation on a fast growing plant since the county only allows 4' (front) and 6' (back) fence height and I need something to block out the neighbors.
seasons have passed and after countless watering and miraclegro, etc. my privets are only 4' and require pruning while the guy across the street planted bamboo no more than a year ago, I never see him watering or pruning and his stuff's a good 6' tall now.
I'm ripping up the privet and planting bamboo, hope this saves someone else from the same mistake,
-MC
Old 06-13-08, 11:31 AM
What variety of privet did you plant? Depending on variety, height can vary from 4' to 15' or more and 4' to 8' in width. Sounds like you did not purchase the correct cultivar to meet your needs. Had you done your homework, you would have had the right cultivar to meet your height and privacy needs.
Be cautious when choosing bamboo. There are different varieties, and some can be very invasive. Bamboo varieties vary from 1' to 120' in height. Running bamboo can take over a landscape. Underground rhizomes can spread 5' or more in one year. Root barriers are recommended to contain running bamboo. Clumping bamboo is not invasive and may grow an inch a year.
If you live in a cold climate, there are cold hardy varieties.
One should learn to do his homework before purchasing plants for the landscape. There are many cultivars of different plants. It is important to purchase the one that best meets your needs and will do well in your growing environment. It is also important to know the characteristics of the plants and needs for care and maintenance.
Old 06-13-08, 11:55 AM
ok so I think I was wayyy out of my league on this whole thing
you're talking about cultivar ... I don't even know what that is
I'm just gonna go the path of least resistance and leave the privet as is
once the wood fence goes kaput I'll replace it with a fast growing bamboo complete with root barrier
thks
Old 06-13-08, 07:15 PM
In my experience, planting bamboo is right up there with planting kudzu. Most are sorry it was planted. Bamboo is harder to eliminate than a bad reputation.
Old 06-14-08, 08:56 AM
Michael, I looked back and found your original post. I didn't see privet recommended, but it does sound like you planted the dwarf variety.
I agree with the others that bamboo might not be a good choice. Consider Thuja aka Arbrovitae or a variety of holly aka Ilex. With most hollies you will need one male and the rest females so you can have berries. These are named and will be easy to select the males and females. Here's some ideas.
These grow to about 10'.
Ilex 'Mesog' CHINA GIRL
http://www.mobot.org/gardeninghelp/p....asp?code=D490
Ilex 'Mesdob' CHINA BOY
http://www.mobot.org/gardeninghelp/p....asp?code=D480
These grow to about 8' to 10'.
Ilex x meserveae BLUE PRINCE
http://www.mobot.org/gardeninghelp/p....asp?code=D460
Ilex x meserveae BLUE PRINCESS
http://www.mobot.org/gardeninghelp/p....asp?code=D470
Newt
