a river runs into it......
Old 07-22-08, 03:12 PM
I have a 25 year old house. I have a large pool and patterned concrete deck. At the corner of my house it is a low spot on the property. Mine and neighbours property water drains through the garden across the concrete and into a window well. Sunday we had a violent storm. Rain literally filled the window well to the top, water gushing in at the seams of the window, and pouring into the window well. This isn't the first time. I've cleared the bottom of the window well of debris and scooped out as much stone from the drain to see if there is any blockage...seems fine. The real issue I believe is the diverting rain water. As this is an established property, with large plantings and an existing wood fence I 'THINK" the resolve is a trench and weeping tile along the fence line and out to the front...however a hot tub and shed are in the way. I'm at a loss as to what might work or even who to contact to undertake this project...happy to give it a whirl...any ideas from the experts?...it's a very gradual grade....thanks in advance everyone
John
Old 08-13-08, 10:34 PM
Hi John,
I was wondering if you ever got any help with this. I am thinking that a consult with a landscape architect who understands water issues might be helpful for you.
Newt
Old 08-22-08, 05:04 PM
A consultation with a landscape engineer is certainly in order to address drainage issues. No matter what route you take, you should have a drain in the bottom of the window well that carries away excess water. Drain should slope downward away from well and tie into storm drain or drain into a dry well. Placement of drain should be decided upon after deciding where other projects will be placed in the landscape. Dealing with your own drainage issues is enough without having to deal with neighbor's runoff. A landscape engineer can help with placement of drains, ditches, swales, etc. to prevent neighbor's runoff from accessing your property and to prevent yours from draining on to neighbor's property or toward your home.
