Landscape lighting problem...
Old 09-09-08, 12:41 AM
While planting some flowers I accidently cut a 1/2 in slice in my landscape lighting cable. I wrapped it with electrical tape and reburied the wire. Will this be a problem in the future. The wire was not cut through, just the rubber coating. How can i fix this without replacing the entire run?
Old 09-19-08, 07:05 AM
I wouldn't worry too much about it. I think it will be fine.
Old 10-21-08, 12:16 PM
lbphathead, check to make sure you used electrical tape that is water resistant. If you aren't sure what it looks like you can do a google with terms such as:
electrical tape + water
Newt
