Broken 90 elbow in underground sprinkler
Old 10-25-08, 01:01 AM
R
Question Broken 90 elbow in underground sprinkler
Today I found a broken elbow (90degree) in my sprinkler system. Is there a simple and efficient way to replace that without having to use many other connections on the pvc pipe?
Thanks
Old 10-25-08, 06:04 PM
B
I fit is laying horizontal you can dig a big enough hole to get a little flex from the pipes and install two 45's. It will leave you with two less joints than an elbow and two couplings.
B
Old 10-26-08, 06:06 AM
R
Sorry wrong description
Thanks
Sorry I wrote this totally wrong. It is the 45 (or sometimes called L) attachement that broke off.....how do I replace that now that the pipes are further apart without too many connections?
Old 10-26-08, 08:50 AM
G
You will have to cut back on eather side of the pipe and then glue couplrers and cut a peice of pvc to fit, then glue in the new elbow.
