PVC irrigation line under concrete walk
I plan to add a new zone to my irrigation system in Central Florida. To do so I need to run a PVC pipe under a 4' concrete walk. Can anyone explain the procedure to do so? I know it involves using water pressure but I'm not quite sure how it's done!
Hi Buzcar,
There are different ways to do this.
http://www.askthebuilder.com/524_Tun...riveways.shtml
http://www.renovation-headquarters.c...tal-boring.htm
There are also products you can purchase and possibly rent.
https://www.evergreensprinklers.com/...60&page=2&js=n
http://www.bulletmole.com/
Newt
Newt
Be careful when doing so--if you remove too much soil the sidewalk will crack and sink and then the city will figure out what happened.
Use a pipe 1 size above the one you want to pound through. Once you do, use it as a sleeve for the pipe you want to actually use.
