Basic landscape tips needed
Received 0 Votes
Going to be putting in a small landscaped area on one side of a 12' shed, it is just flat lawn right now.
Does all this make sense:
Mark the area, and chop a line in the lawn with a spade, then peel off the sod.
Spray area with Roundup and wait a few days.
Rototill area along with some black dirt (about a yard)and peat moss and plant plants (just a couple bushes and grass, sort of aiming it at stuff birds will like, on the bushes a couple serviceberry bushes and some perenial ornamental grasses, considering Prairie dropseed grass. I think the birds would "use" both of these. Will also be putting a couple bird feeders and a birdbath in this area).
Will then put some weed-x down and cover with shredded bark.
Am debating whether to use an edge around it or not and when would I put that down if i do it, after the rototilling?
Gilly
Gilly
Received 0 Votes
You don't apply RoundUp to bare or cleared groud you apply it to the growth so a better way is roundup first,wait a few days then clear the ground.You want the roundup to be absorbed by the plant and spread to the roots before removing top growth.
As long as the ground is level a weed block is fine but if it is not level sometimes mulch will wash away if it's on a weed block.
As for edging,totally up to you and probably easier to put in ahead of filling the area but after any tilling.
Received 0 Votes
Rototill area along with some black dirt (about a yard)and peat moss...
I don't recommend peat moss as it's low in nutrients, can lower the pH of your soil (it's highly acid), it's not a good thing for the environment and once dry, is difficult to rewet. Here's some helpful info about peat moss.
http://www.gardening.cornell.edu/fac...rgmatter/#peat
http://www.wildlifetrust.org.uk/facts/peat.htm
http://www.rbgkew.org.uk/ksheets/peat.html#help
You can purchase compost in bags or bulk. Here's a calculator you can use to determine how much you will need. I'm also including a mulch calculator.
http://www.cedar-grove.com/compost_calculator.asp
http://www.atstecks.com/mulch.htm
...and plant plants (just a couple bushes and grass, sort of aiming it at stuff birds will like...
http://www.gardenguides.com/how-to/t...berrybirds.asp
http://www.wildbirds.org/newintro.htm
http://www.springmeadownursery.com/article_6.htm
http://web.extension.uiuc.edu/champa...rs/031108.html
http://www.pineridgegardens.com/birdfood.htm#plants
http://www.birdnature.com/trees.html
http://www.gwf.org/resources/wildlif...thebasics.html
Viburnums are are great for birds, but some are better at bearing berries then others and they come in different sizes.
http://www.sylvannursery.com/pdf/viburnum.pdf
...on the bushes a couple serviceberry bushes and some perenial ornamental grasses, considering Prairie dropseed grass. I think the birds would "use" both of these. Will also be putting a couple bird feeders and a birdbath in this area).
http://www.hgtv.com/home-improvement...ion/index.html
I'll be leaving shortly and won't have computer access for a week, but I suggest you do a google search for any plants recommended. If you decide to plant a honeysuckle for the hummers and birds, be sure to plant the native Lonicera sempervirens. There are many beautiful named cultivars now, but be sure it has that botanical name as the others are invasive in the environment. Lonicera sempervirens will bloom on and off from early May until hard frost. You can make a hinged fold down trellis against the shed.
http://www.michaelholigan.com/depart...8G2J3N3AT0A50#
Newt
