Round Up Or Bleach
Old 03-08-11, 07:00 PM
Round Up Or Bleach
Hello,
There is an area behind my property that was full of weeds and vines. I cleaned it up last Fall. The township only mows the grass from 4 feet off the road. beyond that is where I cleared and cleaned most of the brush, weeds and vines. Some property owners have already done the same thing and planted fescue.
This Spring when new growth starts, I was thinking of using Roundup to kill everything. But at about $23.00 for 1.33 gallon, it may need more then I anticipated.
So I was wondering if I can use bleach instead. I do not intend to plant anything until Spring of 2012.
Would this cause a problem?
Old 03-09-11, 04:26 AM
how about salt and vinegar
Old 03-09-11, 08:56 AM
Home made remedies may work for the weak species of weeds but I have these 1/16 to 1/8th size vines or roots running along the top of the soil. I believe these may be coming from weeds that grew into trees and I have 5 of these growing behind my property. I rather see these trees killed and then replace with 2 trees that will give me some color in the fall.
So I am sure I will need something stronger then what you suggest.
What I am looking for is:
Will the application of bleach kill all vegetation including trees and what are the effects on the soil after 1 year from the application.
Old 03-09-11, 09:19 AM
Roundup takes more than one application on tough weeds but you can usually buy concentrates which you dilute and that brings the price down (you want about a 2% solution)
Vinegar is effective as well, I would not use bleach
Old 03-09-11, 09:36 AM
And what would be the rate of vinegar application to water or do I use it full strength?
Old 03-09-11, 05:04 PM
GregH's Avatar
Super Moderator
Bleach or vinegar will do little to get rid of the weeds.
They both would have the same effect as mowing.
Unfortunately there is a reason Round-Up is so expensive and that is because it works.
You could try to purchase it in bulk.
Here, at an agricultural supplier it costs about $100.00/10 litres for farm grade concentration and this will last me for several years for a couple of acre rural property.
At what rate do you mix the Round-Up you can get?
If you knew others who also could use some Round-Up you could share a jug.
Old 03-09-11, 06:46 PM
<If you knew others who also could use some Round-Up you could share a jug.>
Afraid not. My neighbors are content with the way their areas look.
Old 03-09-11, 07:16 PM
GregH's Avatar
Super Moderator
"At what rate do you mix the Round-Up you can get?"
