Replacing Toro Super 600 Sprinkler Heads
Old 05-14-11, 10:25 PM
Can't seem to find these anywhere in stores or online. Any recommendations for good replacement?
Old 05-14-11, 11:27 PM
lawrosa's Avatar
Super Moderator
The orbit voyager II found at the homestores, or hunter PGP at irrigation stores.
Just make sure you match the GPM on the nozzle and change accordingly.
Mike NJ
Old 05-15-11, 06:11 AM
Have you tried contacting Toro? I bet they have a modern equivalent. I probably just has a different name or number.
Old 05-15-11, 09:35 AM
Thanks for the help, I will take a look at these and contact Toro for a recommendation. Are these all about the same quality? Cost?
Old 05-15-11, 10:40 AM
Most brands have a less expensive plastic line and a more expensive brass or stainless steel line. If you are in a coastal area with salt spray and sand I might consider the more premium ones but from what I've seen the plastic ones hold up OK for home use. Freezing and driving over them with a car seems to be the biggest killer in my experience.
Old 05-15-11, 12:21 PM
I am in northern NJ, not by the coast. The only salt and sand is for winter driving and the sprinklers are covered with snow by then. No cars on the lawn so that's not an issue. I guess plastic is good enough.
Old 05-18-11, 03:10 PM
Well, Toro indicates the Super 800 is the current model for the Super 600. However, the documentation for the Super 800 indicates it has a 5" pop-up. The Super 600 (S600 PC 2.5) heads I have seem to be a 4" body with a 2" (?) pop-up. I imagine I would need to do some extra work to get the 800's to fit without sticking up from the ground. Not sure this is the way I want to go.
Old 05-19-11, 08:25 AM
You could always replace them with a different brand. I think my father has three different brands on his system at the coast.
