Sprinkler Issues - Please Help!
Old 06-20-11, 08:39 PM
I have a three zone sprinkler system. Up until a week ago all three were working. Now, just zone 1 is working. The other two make absolutely no noise when I try to run them manually.
It does not sound like it is clicking on or that water is running through it.
Please help!
Old 06-21-11, 05:12 PM
mike1059's Avatar
If it's an automatic system, it sounds like a bad wire connection for the common wire. Look at the wires at the valves and there should be one wire connected to all three valves. Re-do that connection and see if that fixes the problem. One question I should ask is how did you try to manualy run the valves, at the clock or the valves. If it's a manual system sometimes the handles wear out and will no longer turn the shaft of the valve.
