Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Lawns, Landscaping and Outdoor Decor
Reload this Page >
How important are the runners and risers for lawn sprinklers?
Old 06-27-11, 12:22 PM
From what I have been reading, some insist on using runners and risers when laying the pipe for a sprinkler system. Basically a 2 layer system.
Others simply use a single runner and feed directly into the pipe.
Are there any pros/cons to either?
Here is an ugly diagram to illustrate.
The image on top is a single runner and simply tapping into it as needed.
The image on the bottom uses a runner but then a riser when ever heads are to feed off the runner.
Old 06-27-11, 01:23 PM
I don't like having a sprinkler head going straight down into the trunk line. If someone steps on it or drives over it with a mower or car that force pushes straight down and might break the trunk line or fitting. If the sprinklers are fed by a line that branches off from the trunk line the sprinkler head hopefully can move a little without breaking the pipe. Having the side branch lines also makes it easier to locate them exactly where needed.
