Drainage for Rock Wall
Old 08-08-11, 03:01 PM
Hello All:
I am preparing to build a dry stacked rock-wall and I am now adding drainage.
I found some white correlated pipes with holes at the 12:00 and 3:00 position that I assume is laid holes up so that the water enters from above but follows the pipe to its final drainage point.
My question is this. How deep do I put the drainage pipe? Do I lay this pipe on top of the gravel/crushed stone footing or beneath it on the dirt.
Regards,
B
Old 08-08-11, 04:57 PM
The pipe is laid with the holes at about 4:00 and 8:00 or close to that. The idea is to collect the water from as low an area as possible. You will need the correct well draining gradation of aggregate and a sock may help for a short term solution of keeping the fines out of the drain pipe. - Use a solid (non-corrugated) pipe to carry the water away.
Dick
Old 09-04-11, 03:58 PM
thanks, what do you mean about the 'short-term'
Is there a longer term solution for keeping the drainage running?
thanks,
--B
