Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Lawns, Landscaping and Outdoor Decor
Reload this Page >
Winterizing sprinklers & the back-flow prevention valve
Old 09-30-11, 06:28 AM
It's almost that time of the year again.
So on my sprinkler system I have the port to hook up the air compressor after the back-flow prevention valve. In the basement where the sprinkler system feeds off the water main for the house there is a little thumb screw bleeder.
So my question is how do I drain the line in-between the water main and the back-flow prevention vale? I don't think i did it right last year and I want to make sure the Back-flow prevention valve is dry before the below freezing temps set in.
thanks
Old 09-30-11, 10:51 PM
mike1059's Avatar
winterizing main line
if there is a ball or gate valve between the tee from the house line and the backflow close that valve, blow out the lines then open all bleeders on the backflow. this will drain the remaining water.
