Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Lawns, Landscaping and Outdoor Decor
Reload this Page >
Best way to handle excess water runoff from neighbors yard
Old 10-14-11, 11:09 AM
R
I have a neighbor along side my house with a lot that is about 1 foot higher than mine. A fence separates the two lots with a 1 foot board placed under the fence so the fence itself starts at the level of the neigbor's lot.
The soil is primarily red clay.
The problem is that all of the runoff from rain or sprinklers from my neighbor's yard spill off onto my lot. You can see the water coming from under the fence. This has the part of my yard by the fence turned into a muddy swamp.
What is the best way to address this situation? Put in a french drain along the fence?
My thought was to use this water to water my landscape, does anyone know of companies which make cisterns that I could store the runoff water in?
Also, would simply adding soil to my yard so it is as high as the neighbors - or a little higher, solve the problem?
Old 10-14-11, 10:19 PM
mike1059's Avatar
I would think a french drain would be the simplest solution but if you want to run the pipe to a cistern with a pump any pipe and pump supply house should be able to help decide what parts would work best for your needs.
