Rubber Hose Repair won't hold
Old 08-14-12, 12:14 PM
My rubber hose developed a bulge, then a leak. I cut out the damaged portion, then used a hose repair clamp, fitted the two sections together and tightened them down. Trouble is the hose continues to part at the clamp on the same side no matter how tight I screw the sections down. Can I score that hose section interior in some way so the clamp has more traction? Might that clamp section be out of round? Any solutions or ideas greatly appreciated.
Old 08-14-12, 12:25 PM
The repair kits come in different sizes - did you get the right size for your hose?
Old 08-14-12, 12:32 PM
Remove the hose repair fitting and cut about a foot of hose off the two sections to make sure you are back to good hose. Then try the repair kit again.
Old 08-14-12, 02:00 PM
chandler's Avatar
You are using barbed connectors, right? http://i.walmartimages.com/i/p/00/04...10_500X500.jpg
