Poly and Water Main Size
Old 03-28-13, 04:39 AM
I have some 1 1/4" poly pipe that I've had for several years now that I'm considering using on my garden sprinklers now, the only thing is, I will be needing more pipe and before I run down to the local store I figured I'd ask my friends here.
How can I benefit (if at all) if I have a 1 1/4" poly pipe connected to a 1" main?
As always all postings are appreciated.
Old 03-28-13, 05:34 AM
The larger pipe will cut the resistance, giving you better flow at the garden. The longer the run is to the garden the more a larger pipe will help. It probably will not be a huge help but it will help. If doing it new I'd probably go with 1" but since you've already got 1 1/4" there is no harm in sticking with it.
Old 03-28-13, 06:37 AM
Thanks Pilot Dane for your reply.
If I need to add to the existing 1 1/4" that I have and decide to use 1" pipe, should I put the 1 closer to the supply or after the 1 1/4"?
I think they call this OCD.
Old 03-28-13, 07:51 AM
I would put the larger pipe closer to the main/supply and the smaller out near your garden.
