toro irrigation timer not working
Old 05-06-13, 04:38 PM
bish80's Avatar
I have a Toro Irrigation timer that is not working. On the control panel there is a water drop with a line through it(see attached). I tried to go to the Toro web site, but they are useless. The water is on to the valves. Any ideas?
Old 05-06-13, 09:17 PM
Received 1,178 Votes on 1,092 Posts
That symbol is associated with the rain sensor system. Apparently the sensor is wet or possibly defective. I think you could disconnect it to see if the system starts working normally. There is also a way to reset the system.
The permalink below is the manual for your unit. After the link opens click on "download toro users guide......."
Toro Users Guide Automatic Outdoor Sprinkler Timer ECx Owners Manual
Old 05-07-13, 03:20 PM
bish80's Avatar
I appreciate the help. I'll try that first.
Old 08-17-13, 12:17 AM
cmpstrctrs's Avatar
Toro sprinkler timer other troubles
Got same sprinkler timer model. Mine is draning backup 9v battery at the rate of one per week. I checked the wall transformer already. Any other ideas?
Old 08-17-13, 12:29 AM
The adapter could be ok but the connection (plug) could be broken. Usually you need to check the power supply with a meter. Then open unit and check it where it comes into unit.
Old 08-17-13, 05:48 PM
cmpstrctrs's Avatar
Thank you. I did check and registered 26v. Transformer is a 24v 750mA. I also checked the wall socket. The sprinkler system runs fine but after a week or so the LCD is blank, the battery is drain, and the irrigation system off line. Shoul I replace the sprinkler timer?
Old 08-18-13, 09:45 AM
Unfortunately since they aren't serviceable..... you will need to replace it.
Old 08-18-13, 09:01 PM
cmpstrctrs's Avatar
Thank you. I will do just that.
