Damaged Hose Outlet?
Old 06-17-13, 01:12 PM
We have two external hose outlets at our home. One is attached to the back of the house and the other is attached in the garage. In both cases, when I connect a garden hose water leaks from the connection.
Interestingly, I've noticed that the threads on both outlets have 2 flat sections, almost as if part of the threads on each side of the outlet were shaved off:
http://imageshack.us/a/img94/3510/0m8r.jpg
http://imageshack.us/a/img856/5732/v9dj.jpg
Any idea what the previous owners could have done to cause this or is this some sort of special connector?
Old 06-17-13, 01:23 PM
Never seen one like that.
See if the vacuum breaker is just screwed onto the faucet. If it is then just remove and replace.
vacuum breaker - Bing Images
Old 06-17-13, 01:28 PM
Gunguy45's Avatar
Super Moderator
The flat sections may have been caused by someone cutting off a fitting or they could be for a special tool to separate the sections? You already have a vacuum breaker sillcock as you can tell by the drop of water on the center pin.
Hose connections seal by use of a washer or o-ring...not the threads. The teflon tape won't help.
I'd try a new rubber washer (not the hard plastic) or O-ring (which I like better) and see what happens.
Pro's will be around later with better advice.
Old 06-17-13, 04:31 PM
It looks like you have vacuum breakers screwed onto the outlet of your faucets. The flats are on the threads so it can be secured with a wrench. Some versions have a locking screw on the side that gets tightened until the head snaps off so it cannot be removed. Required to bring older style hose bibs up to current code. But, a big pair of channel lock pliers or pipe wrench can get them off.
Old 06-18-13, 12:01 AM
Thanks for the great info. I had never heard of vacuum breakers until now, but after reading up on them it makes sense. We have a pool in our backyard so I assume that's why they were installed.
Also, I took a closer look at one of my pictures and based on the markings I was able to find the product page for our vacuum breakers:
8A Hose Connection Vacuum Breakers, Brass, Vacuum Breakers, Backflow Prevention - Watts Canada
The company (Watts) say that this is a non-removable vacuum breaker. I'm going to see if I can just fix it first (they have a repair kit), and if that doesn't work then I'll have to figure out how to remove these ones and replace them with new vacuum breakers.
