Manual starting zone #2 does not come on
Hello.......first time for me here and I could use some expert help. I have 4 zones in my sprinkler system and I had a leak in the black plastic hose in zone 2. I dug down and repaired the pin hole leak so that's fixed. I ran the control panel manually through all 4 zones and #1 worked fine, #2 did not activate, #s 3 and 4 were fine. You can hear the valve open on 1, 3 and 4 but nothing happens when I try to activate #2. What do you think is wrong? Any help is greatly appreciated.
Thanks.
Thanks.
Zone 2 not working
Thanks Kerry......I am first going to blow the lines out with compressed air and see if something is blocking the valve and then I'll open the main valve box and check the wires.
