How to figure yards of topsoil ?
Old 10-14-13, 01:50 PM
I need to cover 2 areas, 2" deep:
1) 30' diameter circle
2) 10' X 20'
Thanks
Old 10-14-13, 02:46 PM
Area of a circle = pi r = 3.14 (15') = 706.5'
706.5' x 2" depth = 117.75'
117.75' x 1 yd/27' = 4.36 yd
10' x 20' x 1/6' = 33 1/3' = 1 1/4 yd
I'd order 6 yards.
Old 10-14-13, 02:50 PM
Gunguy45's Avatar
Super Moderator
First one...30' is 360" to keep measurements the same. Radius is 1/2 that or 180".
Calculating the Volume of a cylinder
Divide result by the cubic inches in a cubic yard. Cubic yd is 46656 cu in.
4.37 cubic yds needed
Second is 120" x 240" x 2" = 57600/ 46656= 1.23 cu yds needed
Total is just under 6 cu yds.
EDIT...Uh oh....one of us is off by about 2 cu yds on the circle. I've checked my using different measurements and I still get the same. Mitch, shouldn't the 2" in the second line actually be a fraction/decimal since 2" is 1/6th/.166 of a ft? Thats where our numbers diverge anyway. I may just not be understanding your math.
Call the Ref!
Old 10-14-13, 08:36 PM
Thanks guys. Someone is wrong!!
Old 10-15-13, 06:48 AM
Cubic Yards
3.1417 x 15 x 15 = 707 sq ft ; 2 in deep = 707/6 = 118 cu ft/ 27 = 4.37 cu yds
10 x 20 = 200 sq ft/6 = 33.3 cu ft/27 = 1.23 cu yd
4.37 + 1.23 = 5.6 cu yd
Is this a tie breaker?
Old 10-15-13, 07:22 AM
GregH's Avatar
Super Moderator
For landscaping you might want to order about 25% more than your calculation to allow for compaction.
Someone already knew this.......right?
Old 10-15-13, 12:18 PM
Hmm... we agree on the rectangle, let me do the math on the circle again.
Old 10-15-13, 12:21 PM
Found an error - 775/6 is not 177; my second line should end 117.75'. This then leads to a total of 4.36 yd, which matches Vic's total.
Sorry about that. I've updated my original post so no one gets confused by it later.
Old 10-17-13, 11:20 AM
When raking the topsoil before seeding, do I want the topsoil height slightly higher than the current grade to allow for settling, or do I make it the same height? If higher, how much higher? Thanks.
