Hunter SRC Sprinkler controller
Old 10-19-13, 12:24 PM
Trying to troubleshoot and need some advice. None of the zones are working. When I turn one zone on manually, I get 28V on the terminal board between all the zones and the common. When I turn it off, there is no voltage between the zone points and the common. I checked continuity by connecting a valve wire to the common and am getting nothing. It sounds like the wire has been cut, but I'm confused as to why I get 28V between all the zones and common when I turn it on. Is there a way to confirm that the controller is good, or have I already? I'm not looking forward to replacing a couple of hundred feet of wire. Any insight appreciated. Thanks.
Old 10-19-13, 01:29 PM
Welcome to the forums.
When a unit shares a common wire strange things can happen. For you to check the controller, you must remove the wiring and then do the voltage checks. Once it's determined that the controller is working ok..... you can move on to the wiring. In the link below is instructions for voltage testing. When you do your testing.... only the selected zone should show +/-24vac between the common and that zone terminal.
Be sure to right down the color code for your wiring before removing the wires.
How do I test voltage at my controller and solenoid? | Hunter Industries
