Landscape lighting Low voltage or 120?
Old 06-05-14, 09:37 AM
bobed2121's Avatar
I'm ready to do some spot lights for a couple trees. I see there is either low voltage lighting or going directly with the 120v. I'll need to run about 100' of wire for my project. I know the 120v requires 18" minimum buried depth and typically run through conduit.
I can go either way here but if the low voltage is an easier install I'd rather do that. I think the transformer cost is pretty steep for low-voltage stuff and why going 120v may be better.
Thoughts?
Old 06-05-14, 04:24 PM
Received 3,632 Upvotes on 3,254 Posts
Low voltage is definitely a quicker and easier install.
Something can be said for both lighting methods.
One key item is what kind of heads are you looking for ?
Old 06-06-14, 09:15 AM
bobed2121's Avatar
Since this is a DIY forum I won't feel dumb asking..."Heads?"
Old 06-06-14, 09:18 AM
Heads...... lighting heads or lighting fixtures.
Old 06-06-14, 11:00 AM
bobed2121's Avatar
6 of the 50w low-voltage floods from Lowes.
Shop Portfolio Black Low-Voltage Halogen Spotlight at Lowes.com
However may spend the extra money and get LED's
Old 06-06-14, 11:09 AM
That's a pretty heavy wattage load. Would require 300 watts of transformer to run them.
Old 06-06-14, 03:42 PM
bobed2121's Avatar
Yes and not leave room for expansion. I'll have to re-consider
